주요 콘텐츠로 건너뛰기
Landline/일반/유선 전화 유선 전화 수리 및 분해 안내서.
496 질문 전체 보기
loud humming on land line cordless phone
I have a two handset cordless phone on a land line. About a week ago it started to have a loud humming buzz that interferes with hearing. I got a new phone (Panasonic) but it still hums. We've added no new electrical devices in the house. I've tried different wall jacks and it still buzzes. I've disconnected our DSL link and that made no difference. I've tried to open the NID but even with the screws out I can't open it. I've set up a visit by a Century Link technician a week from now. Not eager to pay the charge for that. Is there anything else I might try to fix it on my own. Thanks for any help you can give.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @tomehlinger
Is the phone's base station connected directly to a telephone cable or is it connected to a modem and is a VOIP (voice over internet protocol) type service?
If it is a telephone cable connection, it sounds as though there's a line fault e.g. wet cable somewhere, between your premises and the local telephone exchange (telephone switch), which creates noise due to an earth or voltage connection on the line, that shouldn't be there.
Don't know how the fault repair system works where you are but here with this type of problem you can ring the phone service provider (using another phone) and tell them that the line is noisy and that at the moment you have disconnected/unplugged everything from the line at your end so that they can remote test the line to check its condition. If it were OK they would test a clear open circuit line i.e. no foreign earth, no foreign voltage or a leakage to earth condition and no equipment connected to the line
If there is a line fault then they should have to fix it as they are responsible for maintaining the line up to where it enters the premises.
If it tests clear then the problem may be in the wiring within the premises and it is your responsibility to fix it i.e. yourself or pay them or someone else to fix it.
If it is a modem connection, try resetting the modem by powering it off for 5 minutes and then turning it back on again. Allow the modem to initialize before checking the phone service for any noise.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Tom Ehlinger 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 32
전체 시간: 143
