주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3세대 iPhone SE는 3월 9일 (미국 시간 3월 8일) 신제품 출시 행사 Peek Performance Apple에서 소개되었습니다. A15 칩과 4.7인치 LCD 디스플레이가 특징입니다.
Texts are going through as emails
My text messages keep go through as emails. When I go to settings, messages, iMessage. I can’t choose the phone number option. It doesn’t save it and goes back to the email. Does anyone have any suggestions? The calendar is set to automatically update as well
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
@johnmac22911, Not sure if you turn your phone off after updates or even every few weeks to let it reset. But, it's a good practice to do so.
The first thing I recommend doing is shutting off your phone for 5 minutes. Then turn it back on and try and send a text message. See if it sends it from your phone number. Sometimes doing this simple reset can fix the issue.
This next thing might seem obvious, but I have to ask. Is your phone using a cellular network? (Sometimes folks use their phone on WiFi only). If it's on a cellular network, then I would go back into the Settings > Messages > Send & Receive > Click on the Addresses and double check that the, Start New Conversation From box with your phone number is the one that is checked.
If there is a check mark next to your email, then uncheck it. Then click out of messages to go back to settings. Then try sending a text message to test if the settings work.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you for your reply. I tried everything mentioned. The issue seems to be when I uncheck my email under the messages portion of settings.
My phone number shows, however, I’m unable to select it. The wheel simply spins next to my phone number then stops. A check mark doesn’t appear.
@johnmac22911, you're welcome. I'm sorry this didn't work. Have you tried turning Messages off and then back on again?
Go to Settings > iMessage > Toggle Green Switch off.
In my experience it's better to turn iMessage off and then press the back button to go back to the main settings menu. Then wait about a minute and then return back to the iMessage settings to toggle the switch back on.
댓글 달기
답변을 추가하세요
John Mac 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 326
