주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년 10월에 출시된 Google Pixel 6 스마트폰의 수리 및 분해 정보입니다. 모델 번호 GB7N6 및 G9S9B16으로 식별됩니다.
Display does not respond to touch
Phone was dropped, then the touchscreen became intermittently non-responsive. Applying pressure to the sides of the device or providing some flex would get touch functionality to restore for a while. Eventually even this stopped working and the touch functionality stopped working entirely although the display itself is still perfect.
I figured this must be a screen issue though I dont understand why only touch would fail and not display; so I ordered a replacement screen and hooked it up to test but again have the same issue, display works perfect with no touch input being accepted. I inspected the connector/board for the display and don't see anything wrong (although I dont have magnification). I cleaned the board side of the connector with 90% IPA though it made no difference.
Anyone have an idea of what to look for? I understand I will most likely need a new phone at this point but I'm still interested in what went wrong.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
Have you rebooted the phone with the new screen attached? I had one one that needed it to be done twice before the screen was accepted and the touch then worked. You may even have to reset it if just a reboot doesn't work.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Did old screen work? I have the same issue touch is not working even though there is no crack
의 공유
hi i have the same issue there was no cracks whatsoever is there anything u can do about it? or how did u fix it?
의 공유
My Pixel 6 Pro took 5 reboots before it finally recognized the touchscreen and started to work. I still had to run the google tool to enable the fingerprint detector, but that was rather trivial.
의 공유
댓글 달기
답변을 추가하세요
Mike Meller 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 58
전체 시간: 2,410
