주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mac Pro 1세대는 Apple Inc.에서 제조한 Intel Xeon 기반의 워크스테이션 컴퓨터입니다. 1세대 모델에는 2006년부터 2008년까지 출시된 기기가 포함됩니다.
Frequency of memory after upgrade
Hi
I want to upgrade my Mac Pro 3.1 which is currently using 2 x 2.8 Xeon and 8GB 667 Mhz DDR2 memory.
I have 2 Xeon X5460 3.1GHz processors which are designed to work with 667 MHz memory in synchronous mode. I will use them for processor upgrade. What will happen if I also upgrade to 800 MHz memory in such a system? The Mac Pro will use the new memory in asynchronous mode at 800MHz or it will use it in synchronous mode with processor (Xeon X5460) at 667 MHz ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
The Xeon X5460 works fine on my Mac Pro 2008. The memory that is designed to work at 800MHz started at 667MHz.
That is what I wanted because overclocking is not limited by memory now - I can set FSB = 400(equals to "800"), for example, and memory will not stop me from running the processor at that frequency.
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i think it will use it as asynchronous mode at 800MHZ and the 800MHZ memory will be a huge upgrade for your system
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
The main problem with such memory is its enormously huge price. 667MHz sticks are very cheap while the 800MHz ones are 5 times more expensive. So I want to be completely sure before making purchase.
댓글 달기
Sorry no go☹️
The systems driver logic defines the RAM specs in these older systems. Review your exact system here Mac Pro listing
You are also limited to the CPUs listed in the given series. The reason is Apple locks the firmware to what the logic board can support.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I click the link and see that my system originally supports the 800MHz memory working synchronously with the processor. But currently I am using the 667 MHz memory working asynchronously with the processor designed to work synchronously with the 800MHz memory. So the systems driver logic should support both 667 MHz and 800 MHz memory sticks.
I also see my processor in the list of supported ones for my Mac (including stepping specs).
Looks like the previous owner had brains and replaced the expensive 800MHz sticks with the cheap 667MHz ones before selling this Mac to me.
So it is still not clear what will happen in case of using the processor designed for 667MHz memory (Xeon X5460) with the 800MHz memory. Will it work in synchronous or asynchronous mode.
댓글 달기
답변을 추가하세요
Misha Krasnorutsky 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 17
전체 시간: 383
