주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이탈리아 제조업체인 Saeco는 수동, 전자동 및 캡슐형 에스프레소 머신을 제조합니다. 최신 가전제품은 필립스 또는 Gaggia 브랜드로 출시되기도 합니다.
Grinder has no power
Royal Professional, grinder stopped working. It has no power, it must be an electrical problem. Everything else works fine. The question is simply: do I need t replace the control board, the power board, or both? A subquestion: can I test to see which one needs replacing or if there is another reason?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
It seems like there might be an issue with the power supply or control board in your Royal Professional grinder. To diagnose the problem, you can try a few things. First, check if there's power reaching the grinder by testing the outlet. If the outlet is working, but the grinder still has no power, it might be a control board issue. You can also inspect the wiring for any visible damage. If you're unsure, it's best to consult a professional technician to determine if you need to replace the control board, power board, or both.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you. The problem is within the coffee machine - the grinder is integrated and everything BUT the grinder works. I should also mention that the technicians do not wish to touch it as it is a 220V machine. I can buy the parts and replace the board, but I do not know if it is a board and if so, which one, control or power. The technicians would even do the work if I bring in the right parts (they did many years ago when we replaced the boiler).
댓글 달기
Use this video to unmount the grinder, it´s rather easy. (Perhaps you can borrow a grinder anywhere for a test, most grinders from Saeco are equal. One possibility, of course, is a damaged grinder motor.) Things come easier, when you use the testmode: sorry I have only guides in german. To do so shut the device off. Press and hold the two buttons for espresso and water simultaneously and switch the device on. The display shows strange looking numbers. Press the button for espresso and the grinder should work. Then you can measure the voltage on the two wires, should be 230 V AC when working (Caution!!). If there is no such voltage, it might be an issue with the corresponding triac T10 on the main board. You probably will replace it. I wish you success!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
coffee fiend 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 30
전체 시간: 633
