주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
M2는 Mac용 Apple System on a Chip의 두 번째 버전으로, 향상된 성능과 효율성을 위해 통합 GPU, CPU, RAM 및 기타 구성 요소를 포함합니다. Mac mini의 기본 M2는 4개의 고효율 코어, 4개의 고성능 코어를 갖춘 8코어 CPU와 10코어 통합 GPU를 탑재하고 있습니다. 모델 번호 A2686으로 식별할 수 있습니다.
Display not detecting Mac mini
I have a Mac mini m2 and it works fine with the display but the display randomly stopped detecting the mac and says connection not detected.
I have tried:
  • Different monitors
  • Different cables (I’m using hdmi to hdmi)
  • Tried rebooting in safe mode, the screen starts displaying in recovery mode on all of the displays but the moment I select my hard disk to reboot in safe mode, the screen goes blank and connection is lost
  • Disconnecting mouse and keyboard before starting the Mac
  • Double checking that cables are secure and powered on correctly
  • I’ve been on with apple support for tedious amounts of text and calls and nothing helped.
If anyone can please help it’ll be very much appreciated
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
This sounds like a monitor setting issue. If we look at EveryMac M2 specs
So here’s the possible display support. Review the displays or TV’s frequency support as it’s likely the display can’t support the higher resolution the Mac Mini is trying to drive it. The reason it starts off working and as soon as you select the drive the OS’s setting take over.
  • 3840x2160 (4K)
  • 5120x2880 (5K)
  • 6016x3384 (6K)
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
Okay but how do I go about changing the resolution without being able to access the mac at all
의 공유
@zainab63458 - What is your displays ability? Within its settings you should be able to see what its offering as you need to know that first. Some offer Auto Sense Vs Manual could the setting have been altered to Manual?
의 공유
I’m using a Samsung smart tv and it’s manual says it specifically supports Mac resolutions of 640 x 480, 832 x 624, 1152 x 870, i don’t think we altered the settings on the tv and it worked fine before so I don’t think they’ve been set to manual, the tv did give instructions to set picture quality once we plugged in the Mac and we tried it but it didn’t change anything
의 공유
@zainab63458 - All of these options are less than what the system can support as such the system needs to dial back the frequency to match these lesser scan rates.
Do you have access to a 4k (at least) display just so you can manually set it within the systems display settings?
의 공유
Thanks a lot for your help, I tried a bunch of things out and in the end I ended up reinstalling the macOS from recovery mode and it finally booted up, I’m not sure what went wrong but I know it was something with the resolution. Thank you once again.
의 공유
댓글 달기
답변을 추가하세요
Zainab 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 69
전체 시간: 1,374
