주요 콘텐츠로 건너뛰기
2022년 09월 16일에 발표된 Apple의 "작아진" 플래그십 스마트폰은 6.1인치 ProMotion OLED, 트리플 렌즈 후면 카메라, 5G 이동통신이 특징이며 새로 설계한 "Dynamic Island"를 전면 카메라와 상단 세서 주위에 배치했습니다. iPhone 13 Pro의 후속작.
22 질문 전체 보기
hello I have iPhone 14 keeping restarting
hello i have iphone 14 keeping restarting
panic(cpu 2 caller 0xfffffff05dc10fdc): SMC PANIC - ASSERTION FAILED: target/d27/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 40
S.sensor array 0 - 4 is 0x0, 0x400000, 0x0, 0x0, 0x0
F.sensor array 0 is 0x0
- Misc(2) OUTBOX1 not ready
RTKit: RTKit-2413.42.1.release - Client: AppleSMCFirmware-4257.42.2.d27.REL
!UUID: fab53dca-5d4c-3354-a473-f8e57aa561cc
Time: 0x000000010da8c27c
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
@arvind4366, It looks like we haven't got that particular error logged in our Kernel Panics Wiki page yet, but over on repair.wiki, they've got a listing for it.
That's a curious one, as it's not a failure I've personally seen before; the only time I've run into a charging coil failure has been from someone who was doing a rear glass replacement and damaged it.
Anyway, I don't know what might have gone wrong with your phone, but at this point the best advice I can offer is to replace the wireless charging coil and see if that fixes the problem. There don't appear to be any guides available to show you exactly how to replace it, but I'm guessing if you remove the rear glass cover it's mounted on, it should be pretty straight forward to figure out how to replace it. This guide will show you how to remove the rear glass.
iPhone 14 Rear Glass Replacement - iFixit Repair Guide
Luckily, you can also buy that charging coil directly from iFixit as well as other sites like Amazon, eBay and AliExpress.
iPhone 14 Wireless Charging Antenna
Of course, the other choice is that you could replace the entire back panel and thereby sidestep the entire issue of how to replace the coil by itself. You can find those on Amazon and other places. If you go this way, make sure the part you choose specifically says it comes with the charging coil. I think this one fits the bill.
Amazon.com: Rear Back Glass Replacement for iPhone 14 with Middle Frame and Side Key : Cell Phones & Accessories
Good luck and let us know how it turns out!
Note to @flannelist: I've added the 0x40 0000 code to the Kernel Panics Wiki page since it's documented on repair.wiki now.
iPhone 14 Wireless Charging Antenna 이미지
상품
$54.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
as u said i have removed backglass n just refitted problem seems to be fixed.. lets see i will keep for somemore time playing a nice songs n check , thank u so much @Jerry Wheeler
댓글 달기
귀하의 답변을 추가하세요
ARVIND 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 53
전체 시간: 212
