주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation Portal은 PlayStation 5 콘솔의 게임을 Wi-Fi를 통해 스트리밍하여 즐길 수 있는 휴대용 핸드헬드 기기입니다. Portal은 2023년 11월에 출시되었으며 모델 번호는 CFI-Y1001입니다.
Dpad stops responding after multiple inputs
Whenever I move from side to side quickly on my dpad and then hold on the last input, it stops responding until i release the button and press it again. This doesnt happen with the joystick. Im not sure if this is a software issue but I did take mine apart to have a look and didnt see anything obviously wrong or misaligned internally. I dont think its a streaming or lag issue because I can replicate it with the brightness slider from the portals system settings. Is there a hardware issue that I should be looking for that may cause this? I did notice that the blue ribbon under the silicone cap was a little lose and not touching the board on one side but not sure if that would cause this or what to use to secure it to the board.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I didn't know what a Playstation portal was until now, so thanks for introducing me to that.
I think the problem might be with that ribbon. That is all my limited experience can tell you, as I don't know how to fix that.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I found a video for a teardown on YouTube and the guys ribbon cable looks a little loose as well. Around 4 minutes in.
https://youtu.be/qQvzinHu04s?si=LLuUuTLA...
Maybe it’s a software issue, I may try replacing the dpad itself, it looks to be the same as the ps5, but in the meantime I’ll not play any games that need quick dpad movements. Everything else works great so far.
의 공유
댓글 달기
답변을 추가하세요
loudog999 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 22
전체 시간: 701
