주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude D820은 2006년 3월 28일에 출시되었으며, 모델 번호 PP04X로 식별할 수 있습니다.
My computer won't turn on
When I press the power button on the computer, the computer does not turn on, but the control lights next to the power button turn on and blink for a minute and then the computer turns off
LED 1 is lit continuously
LED 2 and 3 are on alternately
Attached is a picture
I would appreciate an answer
Thanks in advance
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
Hi @elchanan1
A blinking caps lock and scroll lock light indicates a motherboard problem (CPU?).
Try removing the ram and start the laptop. If there are no error beeps heard then the motherboard is faulty as ram is checked early on in POST (power on self test) so it hasn't even got that far when starting
Has the laptop been dropped or gotten wet at all?
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
The computer did not fall or get wet
의
@elchanan1
I can only suggest that you download the schematic for the motherboard and check the voltages - see p.47 (CPU voltage) and p.48
의
댓글 달기
Have you tried another outlet? Or cable?
이 답변이 도움이 되었나요?
점수 0
댓글 6개:
I tried another cable and it didn't help
The same fault remained
의
There may be a power failure. It may be the motherboard or battery, both, or something else.
의
Could also be a corrupted OS.
의
I tried turning on the computer only when it is plugged in without a battery and still the same error remains
And it's not an operating system because the bios still doesn't come up
의
Have you tried to check the power button? It may be a problem with the case's power button
의
댓글 1개 더보기
댓글 달기
My first thoughts:
https://www.dell.com/support/kbdoc/en-us...
Have you tried reseating the ram and swapping out modules one at a time?
Bad ram is so often the culprit.
Removing one module at a time, trying only one module, and then swapping them around after reseating them
might fix the issue or at least change your LED indicators.
Have you checked all your internal component connections yet (hdd, videocard, modem, CPU, ODD, etc.)?
It's remotely possible you might need to replace the cooling paste on your CPU after so many years.
If it's cheap and easy, I would replace the BIOS battery just for good measure.
Good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I already tried everything except thermal paste, but thermal paste should not cause such a malfunction
의
댓글 달기
답변을 추가하세요
Elchanan Blumenfeld 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 33
전체 시간: 615
