Wifi doesn't connect automatically!
When I press the wifi icon it doesn't work until i go to wifi settings and keep refreshing the page! I've struggled with this problem although i updated the phone whenever an update is available
좋은 질문입니까?
좋은 질문입니까?
Hi @otamendy99
If it works OK in safe mode but not in normal mode then usually a downloaded app is the cause of the problem.
A downloaded app is one that you downloaded and installed on the phone and wasn't pre-installed on the phone when you first got it.
You will need to uninstall each downloaded app one by one, and test the phone in normal mode between each uninstall to find out if the WiFi activates OK or not. When it does then the last downloaded app that was uninstalled was the culprit.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 4
지난 30일: 13
전체 시간: 426
댓글 2개
Hi @otamendy99,
Does activating the WiFi work OK if you start and use the phone in safe mode?
jayeff 의
@jayeff wow i just tried and it works fine but what should i do to make it good in normal mode?? help
Otmnndy 의
