주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Galaxy A12는 Samsung Galaxy A11의 후속 모델로 2020년 11월 Samsung에서 출시한 보급형 슬레이트 Android 스마트폰입니다. 모델 번호 SM-A125(버전/통신사별 문자가 뒤에 붙음)로 식별할 수 있습니다.
Screen does not work after replacement
Good evening, everyone.
The phone in question fell (the owner said he doesn't know exactly how and where it fell).
After replacing the diplay, including the frame, the phone continues to behave abnormally. I reopened everything and checked to see if any of the connectors were miswired, but everything seems fine. I disconnected and reattached the cable connecting the display and cleaned it with isopropyl alcohol. It continues to behave in the same way.
The site from which I got the display is https://www.e-pol.it/ . I find it reliable, I have always been comfortable with it, had already ordered the same and identical item and repaired another Samsung Galaxy A12 without any problems.
I leave attached a video showing the way the phone behaves (I put my hand in front to cover a child's face in the screen lock picture) and photos of the internal components: https://drive.google.com/drive/folders/1...
UPDATES 19/12/2023
So I have some "updates." In disassembling and reassembling, I noticed that the cables have different initials:
- The abbreviation of the new display is "SM_AO22F."
- The abbreviation of the old display I replaced is "SM-127F".
I leave attached photos: https://drive.google.com/file/d/1sN9wLwy...
I saw that the site sells two types of displays, one with FLAT A022F and the other with FLAT A127F. I don't really know the difference, I have asked here on iFixit in the past and was told that some "components" of the Samsung Galaxy A022 display can interchange with those of the Samsung Galaxy A12.
(see here: What is the difference between these two types of display?)
Remembering that I have another Samsung Galaxy A12 at home that is fully functional, I went to check what initials it had and it has "SM-127F," which is that of the old display.
My suspicion is that they sold me the wrong display or otherwise got something wrong (I am sure I ordered the one with FLAT A127F, I have the proof in the order history). My idea to see if this is indeed the case, or at least to rule it out, is to try to put all the components in this other fully functioning display as soon as I can (I'm replacing piece by piece from one frame to another). If everything works, the problem is the display.
I will let you know, In the meantime if you have anything to saugger me I would be grateful.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I'm in a similar situation, but reversed. I own a sm-a125u and purchased a replacement screen and frame. Was sent to the part for an sm-a125f.
Upon reassembly, it doesn't register touch.
I look at the old part and it's for the sm-ao22f
의 공유
댓글 달기
답변 2개
가장 유용한 답변
You may want to get a new display. If you still have the origanal display, see if you can put that on, and if it works like normal, then it will be a display issue. If it does not, it could be the connector on the logic board, or the phone's GPU.
이 답변이 도움이 되었나요?
점수 2
댓글 8개:
The old display I replaced no longer worked, so I replaced it. The new one I purchased did not either, and it is also original.
The article is this: https://www.e-pol.it/store/product-list/...
It is an Italian site, I find it reliable, I have always used it and never had any problems.
The phone fell on the ground, is it possible that the video card broke? I don't know.
The old display didn't work but I remember it behaving a little differently. If it helps I can replace and put the old one back on and send a video of how it behaves.
의 공유
I don't think that it would be likely that the Graphics Processor in the phone broke, as that is part of the phone's APU chip. It could be the cable connector? Check to see that it is cleaned, and all pins are in place. A picture of the logic board might be nice.
의 공유
Find everything here: https://drive.google.com/drive/folders/1...
If you can use anything else please tell me.
의 공유
@most99 Could you take a picture of the screen cable connector? That way I can see if all pins are in the correct position.
의 공유
Not being sure which cable you were referring to specifically, I took a picture of both. I also took a video, it looks to me like there's glue around it, maybe even between the pins, I wouldn't want that to be a problem. I hope it shows well...
의 공유
댓글 3개 더보기
댓글 달기
From the situation you've described, it appears the primary issue might stem from an incompatibility between the replacement display and the phone's original hardware. Here are the key points and steps to diagnose and potentially resolve the problem:
  1. **Problem Analysis:**
1. **Display Incompatibility:**
- The original display that was replaced had the model number "SM-127F," while the new display has "SM-A022F."
- Samsung Galaxy models sometimes have slight variations between different batches or regions, leading to different connectors or pin configurations. Even if the parts appear similar, they might not be fully compatible.
2. **Possible Connector Issue:**
- You mentioned there might be glue around the pins of the cable connector. If glue or any residue is present between the pins, it could prevent proper contact, leading to the display not functioning correctly.
3. **Potential GPU/Logic Board Damage:**
- Since the phone fell, there’s also a possibility of damage to the logic board or GPU, which could cause the display not to work even if the display itself is fine. However, this is less likely compared to the other issues.
  1. **Steps to Diagnose and Fix:**
1. **Check Compatibility:**
- First, confirm the exact model of the original and replacement displays. If you ordered the wrong model, you may need to return the display and get the correct one (SM-127F for your device).
- Use the other functional Samsung Galaxy A12 to test the new display. If the new display doesn’t work on the fully functional phone, it confirms that the display itself is incompatible or defective.
2. **Inspect and Clean Connectors:**
- Carefully inspect the connectors on both the display and the logic board. If there’s glue or debris, clean it off using isopropyl alcohol (90% or higher) and a soft brush. Ensure the pins are not bent or damaged.
3. **Test with the Old Display:**
- Even though the old display is broken, if it can still show some signs of life, reconnect it to see if it behaves differently than the new one. This can help determine if the problem lies with the new display or elsewhere in the phone.
4. **Check for Other Hardware Damage:**
- If possible, check the logic board for any signs of physical damage. Look for cracks, burnt components, or loose connections. This might require a professional if you're not experienced with hardware repair.
5. **Consult a Professional:**
- If after cleaning and testing the components the problem persists, you might need to take the phone to a professional repair service. They can conduct more advanced diagnostics to check for issues like a faulty logic board or GPU.
  1. **Next Steps:**
- If you identify that the display is indeed the wrong model, contact the seller to arrange for an exchange or return.
- If cleaning and testing the connectors solve the issue, you can proceed with reassembling the phone.
- If none of these steps work, consulting a professional is advisable, as they can perform repairs or further diagnostics beyond basic troubleshooting.
This approach should help you systematically identify the root cause and get your phone back to working condition.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gavino Santu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 31
전체 시간: 2,004
