주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2023년 10월에 출시된 Google Pixel 8 Pro 스마트폰의 수리 및 분해 정보입니다. 모델 번호 G1MNW(NA/AU), GC3VE(EU, 인도), GE9DP(JP)로 식별됩니다.
How to replace the rear assembly.
I need to replace the rear assembly and the screen on my Pixel 8 Pro. The Screen replacement tutorial is there, but the rear assembly replacement tutorial is not. Is there ANY guidance?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
The back panel is what all the components screw into. The best thing to do would be to follow the teardown and put all components back into a new frame.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
The teardown didn't match the device. The backplate includes the thermal sensor. The battery removal strip is useless, use a thin plastic card (I used the iFixit guitar pick tools and then a hotel room key)
The screen replacement arrived with both an adhesive template to lay the adhesive onto the backplate and ALSO adhesives premounted to the back of the screen. Not sure if one should use both or just one.... 🤣
의
it sure does SUCK that not only does google not make & sell the replacement nfc flex cable like its available $15 for pixel 7 pro but they made a whole back glass assembly with the nfc n wireless charging flex cable attached for $172 but still no instructional video can be found ANYWHERE ONLINE as far as i can tell so far
7sell
의
댓글 달기
답변을 추가하세요
Marc Aniballi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 41
전체 시간: 1,858
