주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo 프로세서
How do I fix black screen?
Here are the symptoms:
-When you press the power button, the screen flashes white twice, then stays black. Otherwise, everything else starts up normally with the chime and hard drive sounds, etc.
-Shining a flashlight to the screen shows it still works (just no backlight?)
-I've reset the PRAM, no go
-I've replaced the inverter board but that didn't work
-It does work with an external monitor attached
I am currently running an extended Apple hardware test to see if it brings up anything specific.
Could something on the logic board be bad?
Bad CCFLs?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
The hardware test did not find anything. Bummer.
의
댓글 달기
답변 1개
선택된 해법
It's the screen connection to the board, screen or video card
Here is the screen guide, take it apart and check the screen connector, if nothing, try a a screen
iMac Intel 20" EMC 2266 디스플레이 패널 교체
If not, it's the video card or logicboard(I think this model has a MXM card)
I do not know much about the video card built onto the board or a seprate card, but I know this, if it's a ATI(AMD now) or NVIDIA, it's probably on a separate board, if it's intel, no, on the logicboard itself, you will need to take your iMac apart to know for sure about this
Here is the GPU swap guide
iMac Intel 20" EMC 2133 및 2210 비디오 카드 교체
iMac Intel 20" EMC 2266 디스플레이 패널 이미지
안내서
난이도:
조정
iMac Intel 20" EMC 2133 and 2210 비디오 카드 이미지
안내서
난이도:
조정
1 - 2 hours
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
thank you nick, i really appreciated you, its also solve my problem
의
댓글 달기
답변을 추가하세요
mike 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 2,715
