이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
The depends where the bend is but you can try to remove the wheel(s), insert a bending spring that corresponds to the diameter of the frame of your walker and try to bend it back. If you are not using a srping or something that you can insert into the hollow frame you will risk kinging the metal and woul will be worse off...
honakrisi 의 공유
