주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
삼성 갤럭시 A14 5G는 삼성 전자에서 개발한 안드로이드 스마트폰입니다. 2023년 1월에 출시되었습니다.
How to change the battery
How would one replace or change the battery
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Replace the battery
There are many reasons because you want to replace the battery, you will have to be more specific, the charge does not last, it discharges too much, it discharges very quickly, the charge does not increase, it takes too long to charge, you can specify so we can help you.
댓글 달기
답변 2개
가장 유용한 답변
here is a link to a website page on how to replace the battery on your A14 battery replacement
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My phone won't charge
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Hi Glenn,
What have you done to diagnose the problem so far? Have you verified your charger and cord are both working properly, either by swapping them out or trying them on a different device? Have. you cleaned the charging port? Does your phone indicate that it's charging when you plug it in? Does it work correctly when it's plugged into the charger and dies when unplugged?
As you can see, there's a bit more to this question than just saying "my phone won't charge". The more detail you can give us, the better chance you'll get an answer that will actually help.
댓글 달기
답변을 추가하세요
KEVIN NORTON 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 44
전체 시간: 2,632
