주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Valve가 2015년 11월 10일에 출시한 Steam Controller. 모델 번호 1001.
How to remove stuck batteries?
이미지
I am using a pair of Eneloop pro rechargable NiMH batteries and they can't be pushed out by the lever triggers; it's stuck very hard (can't be rotated while partially dislodged but can be put back into the battery slot) and I'm afraid of damaging the contacts if I pry it.
I will need to put a tape or a piece of ribbons next time as a back up plan to pull it out from the case.
For now can the batteries be safely removed with just unscrewing the plastic cover?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
The small levers are meant to be pushed up and when fully pressed will retract out of the way of the battery (it will "click" and latch in the open position). The lever pushes a wedge behind the battery that shoves the battery sideways so you can lift it out vertically. If you are having any connection between the contacts the latch is not fully extended. You can remove the 4 "grip" screws (You'll need a T6 long screwdriver) to loosen the plastic opening slightly if it's wedged there but if you want to remove the cover completely you will have to take out 3 more screws located under the sticker on the backplate. I've never had any issues with my Eneloop batteries getting stuck and if they fit in they come out with just my thumb and finger for leverage (they are slightly girthier then standard batteries).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
anuanuanu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 26
전체 시간: 727
