주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색. 이 페이지는 사용자가 iPhone 4 문제를 진단하고, 수리하고, 도움을 받을 수 있도록 돕는 것을 목표로 합니다.
iPhone 4 power button issue
So I own this iPhone 4 and it fell out of my hand and then the power button is so hard to press! Can I fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Pawel,
You can almost certainly fix this yourself, and iFixit even has all the guides you need to do that job.
The biggest problem here is that first you'll have to figure out which part is broken. The power button consists of a mechanical button, the part you press with your finger, and then there's the electrical part which is basically a small metal dome that the mechanical button compresses to make the electrical connection. The two parts require very different approaches to fix; it's not too bad of a job to replace the mechanical part, but if its the electrical domed switch itself you have to pretty much gut the phone to get to it.
I'd suggest following the guide to replace the mechanical button first, and once you get to the part where you remove the electrical switch, you can evaluate whether it's the mechanical or the electrical part that's gotten damaged. It could even be just the bracket that holds the electrical switch in place that's been bent. If it's just a bent part, you may be able to straighten it, but if something's broken you may have to order parts, which should be pretty easy to get.
Here's the guide for the mechanical part of the button.
iPhone 4 Power & Lock Button Replacement - iFixit Repair Guide
If that doesn't do the job and you end up needing to replace the electrical switch, then use this guide to do the repair.
iPhone 4 Power & Sensor Cable Replacement - iFixit Repair Guide
As far as parts, like I said they shouldn't be hard to find; I'd suggest starting out checking Amazon, eBay and AliExpress, depending on where in the world you're located and what's available to you.
Good luck; let us know how it turns out!
iPhone 4 전원 및 잠금 버튼 이미지
안내서
iPhone 4 전원 및 잠금 버튼 교체
난이도:
어려움
15 - 30 minutes
iPhone 4 전원 및 센서 케이블 이미지
안내서
iPhone 4 전원 및 센서 케이블 교체
난이도:
어려움
1 - 2 hours
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Pawel C 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 26
전체 시간: 331
