주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2010년과 2011년에 출시된 G73은 Asus의 게이밍 노트북 시리즈입니다. 모델 번호에는 G73JH, G73JW, G73SW가 포함됩니다. 모든 버전은 Intel Core 프로세서와 전용 그래픽 카드를 사용합니다.
Need some help finding good replacement pieces.
Alright, I've got this old thing that was given to me by a family member to try and repair last time I saw them, unfortunately, said family member has since passed, making this computer, the last thing they gave me.
I want to repair it, I was already working on it and such, but now I feel even more determined to repair it.
I've figured out some problems already, my main issue is getting replacement parts from a good source, I don't want a battery that dies in 20 minutes for example. The problem is, this is something that was made over a decade ago, so kinda hard to find replacement parts.
So here I am, hoping that you guys with your wonderful knowledge may be able to help point me in the right direction at least.
The computer itself is a G73SW Model, the battery is long since dead, the charging port is dying, the charger's protective covering is cut, exposing the wires(dog and 2 cats in the house). Not to mention the keyboard, which is, well, let's just say it's in pieces. The touchpad may also need to be replaced.
All in all I need: Battery. Charger. Charger Port. Keyboard.
I may have managed to track down a charger and battery, but I want to make sure that CanadaLaptopBattery.com and LaptopParts.ca are actually good before I get anything.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Considering the age of the device, it would be hard to find new OEM parts across all online platforms, unless someone had bought one and never used it. You should have luck finding the keyboard, power cable, and charger port from donor devices on eBay. I'm not familiar with the sites you provided. Just be aware the charge ports on laptops can either be soldered directly onto the motherboard which will require a skilled tech with the right tools to replace, or it'll be on a separate daughter board which can easily be replaced. As far as the battery, you'll have to settle for an aftermarket battery and their quality can vary so it may take some trial and error to find a good one. I would be skeptical of any "used OEM" or "new OEM" listings on eBay. They don't necessarily check to see if what's being sold matches the listing so someone could be selling a dead battery or one with a high number of cycle counts. Or, if you're REALLY up for it, you might have luck rebuilding that battery pack on your own as it uses lithium ion batteries. But there's quite a lot of risk working with lithium ion cells. Do some research into the proper assembly and handling of lithium ion cells before attempting it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Moth 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 195
