주요 콘텐츠로 건너뛰기
Mid-range phone released September 2019. Alternatively named Redmi K20 Pro in China and India. Features 6.39″ Super AMOLED display, Snapdragon 855 chipset, 4000 mAh battery with 27W fast charging, under-display fingerprint reader, motorized pop-up selfie camera, and a main camera with 48 MP plus an ultrawide 13MP and a 8MP telephoto lens.
20 질문 전체 보기
Xiaomi 9t won't make or receive calls
Have done troubleshooting on all software and done a factory reset. I'm also able to make calls with the sim in different hardware.
Any suggestions what hardware needs to be investigated or replaced to fix this issue?
Note - mobile data and SMS still work, just not calls.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
There are several potential solutions to this issue that have been suggested by different sources. One of the most common suggestions is to check if call barring has been accidentally turned on. Call barring is a feature that blocks incoming and outgoing calls, and if activated, it can prevent any calls from being made or received1. It can be deactivated by going into the phone settings and turning off call barring. The default barring password, if required, is usually 1919
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I've tried looking at call barring options but it is not the issue.
댓글 달기
답변을 추가하세요
Alex 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 104
