주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Galaxy A12는 Samsung Galaxy A11의 후속 모델로 2020년 11월 Samsung에서 출시한 보급형 슬레이트 Android 스마트폰입니다. 모델 번호 SM-A125(버전/통신사별 문자가 뒤에 붙음)로 식별할 수 있습니다.
Fixing my power button
Why is my power button isn't working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 달기
답변 4개
가장 유용한 답변
Although it's hard to be sure just having your question to go on, the first thing to do is make sure it's not a software problem. The best way to do that would be to restore the phone to factory settings (note that you will lose all of your data and pictures), or you can try starting the phone in safe mode. Here's Verizon's instructions for putting your phone in safe mode.
If the power button is still misbehaving, then you most likely will have to replace it. I didn't find any step by step iFixit-style guides for your exact phone, but I did locate on for the A12 Nacho, which is a slightly newer version of yours, but as far as I can tell the replacement procedure for the power button is the same on both.
Manuals / Samsung Galaxy A12 Nacho / Fingerprint sensor and power button - Nobody Calls Me Chicken
There's a video that does match your phone exactly that might be worthwhile for you to view, as it talks about fixing the button that's not working right; as far as I can tell the button basically fell off it's mount and just needed to be remounted in order to work.
how to repair Samsung Galaxy A12 power on button #SamsunggalaxyA12 100%easy idq1009.official - YouTube
Hopefully at least one of the things I've mentioned will help you get your power button going again.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
My phone is off thats the problem. I cannot access it
의 공유
https://youtu.be/SQ6ah1ypZWM
The link above should turn it on
의 공유
댓글 달기
well, when you drop your phone, the power button will probably stop working
what i did is i went to settings, then i enabled double tap to switch it on
it should work
if your pone dies and the power button isn't working, just search "how to power on phone without power button" and it should work
I hope thes helps
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Phone fell in water but only the power button stopped working
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My is too much off and on please and please help me it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Meqsood Hashim 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 22
지난 30일: 79
전체 시간: 4,228
