주요 콘텐츠로 건너뛰기
The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
20 질문 전체 보기
Remove Existing Joystick Solder
I am trying to replace the joystick due to it sticking/stick drift; however, I cannot remove the existing solder. Does anyone have any tips or am I doing it wrong? I also believe I've burnt the circuit board but luckily this is a practice one.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @jayshiz
I would apply flux to the solder joints and use low melt solder to mix with the existing (probably lead free) solder. It will make it easier to reflow them with a heat gun or a soldering iron.
Once you managed to get it out, clean the holes with solder wick and you'll have no problem installing the new stick.
Hope it helps!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
sorry, your initial comment was incredibly helpful, but could you explain more how using a heat gun will reflow, I have a very basic understanding of soldering, but I'm still learning, and there's no tutorials online explaining this. Thanks!
I am in the process of making a guide how to do it. I will link it here so you can follow it along.
댓글 달기
답변을 추가하세요
Jay Shiz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 35
지난 30일: 102
전체 시간: 1,598
