주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 9월 20일에 출시된 Apple의 5세대 스마트워치로, 셀룰러 연결 기능을 선택할 수 있습니다.
Destroyed Heat Dissipation Stickers
In order to remove the three display cable connectors, I completely destroyed the three pieces of extremely thin, black, heat dissipation (hd) stickers that covered each of the connections. I saw that ifixit carries a replacement hd sticker kit for the Series 6 44mm watch only. It’s out of stock so I can’t even try to adapt it for my Series 5. Is it absolutely necessary to replace the hd stickers? Is there an acceptable alternative hd sticker here on ifixit or on the internet I could use? Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
The tape is EMI shielding not heat. Finding the die-cut part is very hard.
The solution is to patch up what you have. I use this tape to patch things up Conductive Copper Tape 100% Pure Double Sided Adhesive Copper Foil Tape for Stained Glass, Guitars, EMI Shielding, Electric Connections, Repairs, Grounding, Crafts (1inch x 66FT)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Happy Dad 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 12
지난 30일: 22
전체 시간: 335
