주요 콘텐츠로 건너뛰기
Released in July 1983 in Japan, the Nintendo Family Computer, or Famicom, is the matching predecessor to the Nintendo Entertainment System (NES). Model HVC-001.
10 질문 전체 보기
I Plugged in my AC adapter to my unit and it burned...?
okay so i tried to test my famicom last night and i plugged the original AC adapter that came in the box with it into the wall and the system over heated and started smoking and now wont turn on. what do i need to replace? i took it apart and saw that the heat was coming from around where the AC imput is.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Ryan, check your AC adapter first. The values of your AC adapter are Input: AC100V 50/60Hz 18VA, Output: DC10V 850mA center minus (+-@--). Follow this teardown to get to the inside of your Famicom. You can get the circuit diagram from this question. Hope this helps to get you started, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
@oldturkey - True, the primary of the ac adapter could have a voltage mismatch, but I think it unlikely unless of course Ryan had moved to a country where the primary voltage is now 220Vac instead of the original 110Vac?
@Ryan - Please understand the notion of cause and effect in electronics. If the power supply fails (the effect) then it is because it is suffering from a too large a load (the cause).
This excessive load could be caused by the famicom itself as perhaps a voltage regulator or something else has failed and is in effect behaving like a short between + and - of the supply input (this would also hold true if a pet chewing on the adapter output wires resulted in shorting the + and -). Hence if you simply replace the AC adapter and try to plug the new one into your famicom, then this new adapter will also cook, crash and burn.
It is important to understand that the load on the secondary of the transformer is "reflected" onto the primary, hence it is the primary that also overheats. When a transformer overheats, the resin coatings on the copper wires that constitute the coils become brittle and in some cases just burn away, resulting in short circuits between adjacent windings. This in turn creates a shorter and shorter circuit, resulting in more and more reflected/non-reflected current flow, resulting in more and more heat being generated. A snowball effect; or better put, thermal-runaway.
But all this is just a bit of common sense being applied to speculative faultfinding.
Pictures and some multimeter skills would be best.
Good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Ryan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 21
전체 시간: 4,091
