Why it became hang
my pc become slower than before it hang alot
좋은 질문입니까?
If your computer has been freezing/hanging a lot, there could be several causes. You may want to start with checking on how much space is left on your drives. If any of your drives are almost full, this can cause slower, worse performance, which can be solved by clearing some space on the drive. Before deleting files to free space, check to see if you have a second slot for an additional SSD (Solid State Drive). This will add more space.
Another reason could be due to a hard drive. These are mechanical, so they perform slower than modern SSDs. If you still have a mechanical hard drive, I recommend replacing it with an SSD.
Hope this answer helps your freezing/hanging problem. :)
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 17
전체 시간: 240
