주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pc Shut down after 1sec
When i plug my pc is automatically power on the after 1second it shutdown, if i press the power button nothing happens but it i unplug and replug the charger it startup and after 1 second it shut down again
I had The issue of the pc automatically powering on when i plug but before it start up>shut down>start up normally but it didn't really bother me
And i don't have a battery
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Good afternoon, my PC turns on by itself when I plug in the charger, and the mouse also moves on its own; if you click in one place, it clicks in another. I was using a 19.5w charger, realized I needed one and switched to an 18.5w one (which is the correct one for the PC). What should I do?
의
댓글 달기
답변 1개
It's shutting down because the charger/power adapter you're using is not the OEM charger that it came with, and it's not providing the right amount of Watts/Volts in order to power it up fully so it shuts down immediately since there is no battery. Or it's the OEM charger and it's going bad or the laptop put itself in a low-charge state which then the adapter wont deliver the right amount of power and since there is no battery it immediately shuts off. It's best if you find a replacement battery that way it has the ability to charge and work the way it's meant to.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ilias 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 15
전체 시간: 330
