주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony WH-1000XM3 무선 노이즈 캔슬링 오버이어 헤드폰 수리 및 분해 정보입니다.
Right speaker Isnt working.
The right ear cup isnt producing any audio. The swipe functions on it still work when switching songs and pause and unpausing. Also the left ear cup does produce audio. The headphones can charge and the noise cancellation features also still work.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I assume you are speaking of wireless operation. Is it the same with cable? If yes, then It must be speaker problem.
If the rt works with cable, then it is a problem with the internal PCB.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
yes this happens both using a cable and with bluetooth. If its a speaker issue how do i fix it or is it worth buying a new pair?
의 공유
the problems with fixing them is;
1. finding the right part
2. opening up the earphone without breaking something
3. removing/replacing the speaker
4. reassembling
Of course, you probably want to open first to berify the speaker is bad.
If you get a none exact replacement, do you have a critical ear such that you will hear the diff?
의 공유
I appreciate the help, I'm probably going to go to a place and get it fixed there. I've had these since 2019 and I don't want to risk breaking them more. I do really appreciate your help though.
의 공유
댓글 달기
답변을 추가하세요
Abel Mekonen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 22
전체 시간: 549
