주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
20.2 MP 센서를 탑재한 Sony RX100 고급형 콤팩트 카메라 1세대 모델에 대한 수리 가이드 및 지원 정보입니다. Sony Cyber-shot DSC-RX100은 2012년 6월에 출시되었습니다.
Dropped camera - not powering on
I dropped the camera without protection on stone floor. A small crack has formed in the plastic on the left side of the camera seen from the screen, and some parts look a little bit skewed but not much. The power isn’t turning on and when I try to charge it, no light is glowing. All mechanical components are operational and the battery looks intact. Any idea what the problem might be and if it is fixable?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@jacobvedholm this "small crack has formed in the plastic on the left side of the camera seen from the screen, and some parts look a little bit skewed but not much." we would have to seethe damage to evaluate it. If you have no power at all it is possible that you have a couple of torn/loose ribbon cables or worst case scenario; a damaged board. If it comes on but turns off it could be the lens. A lens that does not retract or extended will get the camera to turn off.
기존 질문에 이미지 추가하기 TO work on your camera you can download the SM from the Documents part on this page Sony Cyber-shot DSC-RX100 level 2 is the disassembly etc. and Level 3 are the schematics etc. Let us know and see what you find out
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jacob Vedholm 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 11
지난 30일: 56
전체 시간: 1,152
