주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony PlayStation 2 SCPH-790xx는 PlayStation 2 슬림라인 모델의 네 번째 수정 버전입니다.
No power help please
I've had this model of ps2 for years and im kinda new to electronic repair im trying to figure out if this is a fuse problem. I learned how to use a multimeter to test continuity and im not sure which fuses to check. I've checked the power supply and it's getting 8.6ish volts so it's fine and it comes through to the board near the jack there's a white fuse that says 6.3A on it and the power comes to there but I'm not sure where to check from there....any help would be appreciated please 😁
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Unplug the console. Check that fuse with your multimeter set to continuity mode (the one that beeps). One probe on one side of the fuse, the other probe on the other side of the fuse. Beep=good fuse, no beep=blown fuse.
Voltage dc, test the inputs and outputs on and around PWM IC MB39A116A.
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 6개:
I done this and it is getting continuity
의 공유
@chrischris16630 When you plug it in are you getting the red "standby" light? If yes, when you press the power button what happens? If no standby light then possibly the pwm ic. Power comes in from the port, follow the traces from there. Check along the rails to find where power is flowing and where it seems to have stopped. Voltage dc. It's been a long time since I've worked on those. I do however think I recall that a faulty power button/ribbon cable/board can cause "no power" issues. The problem is there are several reason why a "no power" can happen. PWM IC MB39A116A a little below the power port on the back side of the board.
의 공유
There is no red light when plugged in and I've replaced the power/reset switch and ribbon cable a while back cause i thought of that too and I still get no standby light on it
의 공유
@chrischris16630 See my edit.
의 공유
Ok @RebTech I see where you are talking about but can you tell me where to use my multimeter on it im still kinda new to it 😅
의 공유
댓글 1개 더보기
댓글 달기
답변을 추가하세요
Chris Christiansen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 48
전체 시간: 1,938
