주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Melitta의 전자동 커피 머신 라인업 중 최상위 기기입니다. 모델명 F74/1-100.
Refill beans is always on screen
We are the owners of the Melitta Caffeo Barista TS for 4 years
Recently, the machine has been repeatedly indicating that I should refill beans, but this is filled with beans. I changed the beans and wiped out the container, grinder inside of machine but the problem persists.
Or when Refill beans is on the screen and we press the button to do coffee it did it few times
We tried to soak the brewing block just in water for a,few,hours, we can get 1-2 cups of coffee after that and the issue starts again.
What is interesting when we put in a ground coffee it works without any problems.
What could be the cause?
I would be very grateful about tips: what seems to be problem or who can fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
I haven't worked with this specific model, but as a whole most coffeemakers have a sensor at the base of the hopper (not the container) and just before the grinder. If you feel comfortable taking it apart, you can try to locate the sensor to see if it is functional.
의
댓글 달기
답변 2개
I have also seen this issue with the barista t. The fault came from the double-chamber bean reservoir. Is it easy to switch between the two containers? Probably not! So try to dismantle it. There is an axle, which is not in the right position (if you have good luck), or worse, which is broken. I wish you a successful repair!
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
See this guide, step 8.
의
Este problema surge en el modelo TS, en el modelo T el mecanismo de la doble cámara es manual,se acciona con la mano.
의
댓글 달기
Hola. Yo he tenido ese problema en la Barista t, y lo pude solucionar haciendo limpieza.
Mete la pastilla en el conducto de café en polvo
Vuelve a hacerlo.
Descalcificar la máquina.
Deja a remojo la unidad de preparación un par de horas con agua tibia y un poquito de detergente.
Hay un conducto interno que va del molinillo a la unidad de preparación, limpialo, está rá atascado.
Mueve la palanca de grado de molienda , cuando intenta arrancar. Puede estar obstruido.
Si estoy no funciona , puede q sea problema de sensores, pero ya lo tiene que solucionar personal especializado
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ganna Sachkova 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 44
전체 시간: 1,635
