주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
삼성 최초의 투인원 노트북으로 13.3형 또는 15.6형 스크린, 8GB 또는 16GB RAM, i5 또는 i7 인텔 프로세서 중 선택할 수 있습니다.
Issue with touch screen - fault or cable perhaps?
This is for the NP950QDB-KA1US. Galaxy Book Pro 360
The notebook screen stopped accepting touch response on the top 10mm of the screen, and a row of the round touch circles would display up there from time to time when moving the lid or trying to touch that region. They show up when restarting at times as well.
The notebook warranty ended in mid-2023. I ran through all of the Samsung updates, Windows updates, and with Samsung's text message support, backed up the files and did a Windows recovery reset, and tried recalibration of the touch screen several times, but the problem remains.
Now, the touch screen response seems to work on and off, but the top region still does not respond. It means you cannot maximize/minimize/close a full-screen window by touch. Also, when the row of touch circles appear, they activate any buttons that are beneath them.
I do not have the tools to pry the notebook open, and despite curiosity, do not have much time to dig around. The question is, how likely is this a loose or slipped cable issue vs. a hardware fault?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Have you tried reinstalling the driver for the touchscreen? Should be available in the device management program.
Press 'Windows + R' on your keyboard, type devmgmt. msc, and hit Enter.
If this doesn't help I would probably have a look at this manual
https://www.manualslib.com/manual/315328...
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Everything was reinstalled with the Windows reinstall, done twice. The issue appears in response to movement and gentle tapping of the lid, so it is a hardware issue. My question is whether anyone else has seen this issue before, and whether anyone has seen a partially loose cable cause this issue?
의
It can either be that or a broken line in a cable depending on connection type
의
We decided to send it off for repair, so we will see what happens. Thank you!
의
@sean72 Always happy to help.
의
댓글 달기
답변을 추가하세요
Sean72 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 34
전체 시간: 517
