주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony WH-1000XM5는 2022년 5월 20일에 출시되었습니다. Sony의 오버이어 노이즈 캔슬링 헤드폰입니다.
Only play on right side
They will only play (make any kind of noice) on the right side, with or without cable.
Is this a common problem and is it possible to fix by myself?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I had this happen to my old pair of headphones, back before I was into repairing tech, so I simply replaced them.
Before getting rid of them I did inspect them, and found that the wire leading to the other side, had frayed and been damaged.
My suggestion is to first inspect the headphones. Another tactic is to go into your devices settings, and set it so that it only plays noise on the right side, once you do this, take them off (DO NOT WEAR THEM FOR THIS TEST) and set your volume to MAX, you should be able to hear this way without wearing the headphones. Then, take the headphones, and fidget around with them a bit; rotate the ear pieces and move them around while listening for noise. You might get some noise when doing this, meaning that it’s probably the wiring. I suggest doing this in wired mode and not Bluetooth
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Cerb 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 46
전체 시간: 1,038
