주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone에 대한 수리 정보, 문제해결 팁 및 안내서입니다. 모델: A1428, A1429
iPhone not turning on
Hey everyone, I have this old iPhone 5 I’d really like to get working again. Started with a battery replacement and I got some life, I could hear sound and Siri worked, however the screen wasn’t on. So I changed the screen. Still the same issue had sound, saw it come up on iTunes, and after a little bit I had no life. I know there are many possibilities but since I did have life, I’m wondering if the charging port just was fried. Before purchasing a replacement any thoughts on anything else I could try? Or anything I might be missing in terms of another fix? Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I'm not sure if I follow the possibility of a charging port being the issue. It sounds like the main potential problems are:
  1. The Screen
  2. Damage to the logic board during the battery replacement
The fact that the computer recognizes the phone indicates that the charging port works fine, and the fact that you can hear the sound coming from the device indicates that it is booting up.
I would try a replacement screen first. The LCD could have gone out or been damaged in some way. If that doesn't work I would assume there was damage done to the logic board during the battery swap, such as a blown backlight diode or blown backlight fuse. These repairs require microsoldering, but the components are pretty cheap.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Tharrett 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 211
