주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
{A1706 / EMC 3071}—2017년 6월에 출시된 이 13" MacBook Pro는 최대 3.5 GHz Core i7(Turbo Boost 최대 4.0 GHz)까지 지원하는 Kaby Lake 프로세서를 탑재하고 있습니다.
T key on keyboard has come loose. How do I replace it?
I have a 2017 13 inch MacBook Pro where only the T key has come loose from its fixing. What do I need to do to replace it? Tx
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@roish most likely time to replace the key cap. Here is the guide for the Key Cap Replacement One of the crucial things to keep in mind is that Apple makes it clear that "Although keycaps can be replaced, the butterfly and switch housing cannot. A damaged switch housing or butterfly requires replacement of the entire top case." You also want to read through this wiki MacBook Keyboard Not Working for more on the diagnostic and replacement. To determine the proper keypad part number, you will have to identify your computer a little bit better. Choose the right one from here MacBook Pro 13" Retina Display or use your serial number to identify your MBP. The Apple part numbers differ based on the model you have
Depending on your geographic location, keycaps are available at places like this and many more.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Ro Ish 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 23
전체 시간: 279
