주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년 10월에 출시된 Google Pixel 6 스마트폰의 수리 및 분해 정보입니다. 모델 번호 GB7N6 및 G9S9B16으로 식별됩니다.
Extremely dim screen after replacement
Hello!
I replaced the display assembly and battery on my Pixel 6 today, and after putting it back together, the display is extremely dim. It almost looks like a dead backlight on an LCD screen. Touch works fine, battery works fine, but it's extremely dim. I tried replacing the old display (I believe only the glass was cracked), but it had the same issues. What could be the possible cause of this? Could it be caused by the battery replacement? Did I scratch something on the connector?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
That sounds like a logic board issue (if you know how) please test the output into the screen with a multimeter
의
댓글 달기
답변 1개
가장 유용한 답변
This is a common problem when static build-up shocks the logic board and damages the backlight filter or backlight fuse. If this is the case the problem can only be fixed via micro soldering repair. Fortunately, the repair is straightforward and the components only cost a couple of cents. Labor will likely be between $50 and $100.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Hello Matt, I seem to have the same issue after replacing the screen of my pixel 8a. Does the entire logic board need to be replace for the fix?
Can the fix be done via access after removing the screen, or does the back case have to be removed?
Do you have a link to a guided repair?
의
@jess86973 I'm afraid Matt's comment really isn't applicable here, as the Pixel 6 has an OLED display, thus no backlight. Same with your Pixel 8a; it doesn't have a backlight either, so the problem is somewhere else. I know the guides all warn to be careful disconnecting the display, presumably because there are components mounted all around the connector that can get knocked off if the spudger gets misplaced. I'd check carefully for any missing parts next to the plug as the first step.
의
댓글 달기
답변을 추가하세요
strndr ​ 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 28
전체 시간: 528
