주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1996년 6월 23일에 출시된 모델 NUS-001인 N64는 닌텐도의 첫 번째 64비트 게임기이자, 스위치(Switch)가 출시되기 전까지 유일한 64비트 게임기였습니다(게임큐브, Wii, Wii U도 64비트 부동 소수점 연산은 수행할 수 있었으나, 완전한 64비트 아키텍처는 아닙니다).
Incredibly dark image - help!
Hi,
Found my old N64 tucked away and trying to get it to work.
It’s on a SCART cable, and I get audio just fine, but the image in the screen is INCREDIBLY dark. Like not there at all. With brightness/contrast settings cranked on the TV you can just about make out the image.
I’ve re-seated and cleaned all cables and the expansion pack, and tried multiple games
Any ideas?
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
Hey there, are you trying to play your N64 on an HD TV or using a CRT TV?
의
HDTV.
Thanks
의
Have you tried using different games, and tried cleaning the N64 cartridge’s pins?
의
@spawn2048 how do you connect your N64 to your HDTV? Have you tried an older TV? what make and model is your TV?
의
@jmehnert yes, as stated in the original question…
의
댓글 달기
답변 1개
가장 유용한 답변
Hi!
I advise to clean the AV port first. If that didn’t worked, then replace the AV cable for a new one. If that didn’t worked, then try the console on a different TV to determine if there is something wrong with the console. If the image is like still super dark, then open up the console and clean it all (also the cartridge pins on the motherboard) and try again.
Could you also share some pictures regarding how the console is connected to your TV?
Please let us know how it goes!
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Bit the bullet and bought a new cable. Now on AV rather than SCART and working fine. So either broken cable, or broken SCART port on TV
의
Hi!
Alright. Probably the cable (in most cases). You could try the SCART port with the new cable. Could be the SCART adapter as well. Good to hear that all is ok now :)!
의
댓글 달기
답변을 추가하세요
spawn2048 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 30
전체 시간: 1,032
