주요 콘텐츠로 건너뛰기
Nintendo Switch Joy-Con 컨트롤러의 수리 안내서와 정보.
Loose Joy-con’s
Both of my Joy-cons (left and right) are loose and come out of the console very easy, how do i fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
That depends on what you mean by "loose". Can you elaborate on that a bit? Do they wobble around in the rails? Do they pop out as soon as you press on them? We need to know the specific problem to be able to help fix it
댓글 달기
답변 1개
가장 유용한 답변
I ran into something that sounds similar on my granddaughter's Switch; while I wouldn't have described it as "loose", one of the Joy-Cons did slide off the Switch console very easily and often at inopportune times.
The fix for her Switch was to replace the little locking mechanism, called the buckle lock. It's basically a piece of plastic with a spring that snaps the Joy-Con onto the rail and keeps it in place. The problem is, the buckle lock is plastic and the rail it snaps into is metal, so it's only a matter of time before the plastic wears down far enough that it won't keep the Joy-Con on the rail any longer.
The fix is fairly straight-forward; you just replace those plastic buckle locks with a pair of metal ones that you can get right here on iFixit.
Nintendo Switch Joy-Con Replacement Metal Buckle Locks
Being made of metal, they won't wear out like the originals. Oh, and you'll be wanting a guide to show you how to put those in, which iFixit also has for you.
Joy-Con Buckle Lock Replacement - iFixit Repair Guide
The only gotcha you'll want to be aware of is that the buckle locks are specific to each side Joy-Con; there's a right hand one and a left hand one. If, like me, you don't notice that fact and put them in the wrong side, they'll go in okay but won't keep the Joy-Con in place. Then you get to go do the whole operation again, only with the correct buckle lock this time. So don't be me, okay? :D
Good luck, and let us know how it goes!
Two metal replacement latches for a pair of Joy-Con Controllers. 이미지
제품
$5.99
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
@dadibrokeit Jerry, thanks for sharing! I was looking for those metal buckle locks!
If both of your Joy-Cons are loose and detach easily, the issue is likely with the small plastic locking latch inside each Joy-Con. Over time, these can wear out. Replacing them with metal latches is a durable solution, and kits are available online that include the necessary tools and guides. Also, inspect and clean the console rails, as dirt or damage can affect the grip. If you’re unsure about repairing it yourself, it’s best to contact Nintendo support or visit a certified repair center.
@michaeldav99184 Michael, I'm at a loss to understand what your comment adds to this discussion. You basically repeated everything I said, with the addition of a suggestion to clean the rails - which being metal, require no real attention.
As far as pointing people to Nintendo or a repair shop, it seems you've missed the entire point of iFixit, which is to empower people to repair their own devices and NOT have to pay someone else to do it.
댓글 달기
답변을 추가하세요
Jpizzano 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 36
지난 7일: 134
지난 30일: 571
전체 시간: 4,509
