Why does it only work on a charger?
my psp go is not turning on and the charging light wont come on either....only when i plug the charger into it and play it will turn on ........if i remove the charger it turns back off.....help pplzzz
좋은 질문입니까?
좋은 질문입니까?
jahtav, sure sounds like a bad battery. It appears like it does not hold a charge. Of course, make sure that the contacts are clean etc. Follow this guide to change your battery. You can get a new battery from here Sony PSP Go Battery as well as many other places. Once you replace the battery, and it still does not charge, you can check the fuses on your logic board. Check those for continuity with a multimeter. Hope this helps, good luck.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 6,767
