주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016 Retina MacBook의 업데이트 버전. 모델 A1534, EMC 3099. 더 빠른 Kaby Lake 프로세서 최대 1.4 GHz Core i7과 Turbo Boost 최대 3.6 GHz, 50% 더 빨라진 SSD, 그리고 최대 2배 메모리 지원을 제공합니다.
Replacement battery no longer working
Hi, I replaced the battery in my daughters MacBook with the kit purchased from iFixit, it was working fine until recently, it now will not charge and in system report it is showing battery cycles 0 and needing attention, any assistance with this will be appreciated.
Thanks
Chris
Update (04/24/24)
Hi Dan, I replaced the battery end of Feb 2023, I have attached a screen shot of the CoconutBattery.
Thanks
Chris
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
When did you replace the battery? And if you can let’s get a snapshot of CoconutBattery main window so we can see all of the batteries data with the charger plugged in posted here so we can see things too.
Update (04/24/24)
@chrismurley - Ouch! This battery is no good. The NaN errors is due to a bad Microcontroller chip within the battery.
Due to COVID chip availability was tight as some battery makers tried salvaging chips from dead batteries. The QC to check these reused chips was let’s say… not well done.
You need a new battery, you might try getting a replacement from where you bought it if they offer a warranty.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I know the warranty on iFixit batteries is one year, but despite that it would be worth your time to talk to the iFixit Store personnel about your situation; I agree with Dan that it looks like the BMS (Battery Management System) on your replacement battery looks pretty dead, so there may be something they can do. Best way is to email them at support@ifixit.com.
댓글 달기
답변을 추가하세요
Chris Murley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 25
전체 시간: 204
