주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung 의류 건조기 수리 정보입니다.
Dryer does not get warm
No heat when running dryer
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Hi Craig,
There are many different Samsung dryer models out there, and figuring out the problem with yours would require us to know which one you have.
Please edit your post to add the model number; that will tell us everything we need to know, but it would be helpful if you could start out by letting us know if this is a gas or electric dryer.
의
I have the same problem with my Samsung dryer model DV42H5000EW/A3.
Can you please help? How do I fix it?
의
댓글 달기
답변 1개
가장 유용한 답변
@lionnely The three most common causes for a dryer that runs normally but does not heat are the thermal cut-off fuse, high-limit thermostat, and heating element. The first thing to do is to test all three for continuity. You'll need an ohmmeter (preferred) or continuity tester to ensure there's a path for electricity through each of those components. If any of them fail, that part would need to be replaced. Here's a video showing how to test them.
Samsung Dryer Heating Element DC97-14486A - How To Test - YouTube
Here are a couple of videos showing you how to access and remove the heater for testing.
Samsung Dryer Not Heating Troubleshooting Made EASY - YouTube
Dryer Not Heating Samsung Common Cause & Repair. Appliance Repair Port St. Lucie, Fl - YouTube
Note that both of these videos show you removing the drum to access the heater, but if you're okay with lying on the floor, it is actually possible to either test those parts without removing the heater at all, or take the heater out without taking out the entire drum. There's only one screw holding the heater in, so if you remove that and unplug it, in most cases you can pull the heater out with the drum still in place. This video shows you how to do that.
Dryer Not Heating Up - Fixed - Samsung Dryer Element Replacement - YouTube
Every time I've run into a dryer that won't heat, it's been one of those three items, so those are definitely the place to start. If you check them and they do all have continuity and the heating element isn't shorted to the case, then come on back and let us know everything you did and we'll see if we can come up with the next steps for you to try.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Craig Chasen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 41
전체 시간: 301
