주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Q405U는 2017년에 출시된 ASUS의 노트북입니다. 인텔 5세대 프로세서를 탑재하고 Windows 10을 운영 체제로 사용하며 다양한 연결성을 지원합니다.
Won't turn on
The notebook not coming on.
When the AC power cord is plugged in the charging light comes on & it's a constant white light. (which means the battery is charged 95-100%)
But when you press the power button it flickers one time and doesn't come on. Also, the charging indicator will flicker off and then come back on as a constant white light after a minute.This is while plugged in.
When the AC power cord isn't plugged in. The power indicator flickers and nothing comes on.
Can someone help me ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
does your charger show any signs of wear or have a loose connection?
if not, does the charge port on the laptop feel loose?
의
No there's no loose connection. The power cord is in great condition. Nothing feels loose near the port
의
댓글 달기
답변 1개
선택된 해법
@cassandradover Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
This "power indicator flickers and nothing comes on" sounds like a bad battery. Get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. You will also have to check the switch as well For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Okay when you say remove the battery. Do you you want me to open up the laptop and disconnect the battery?
의
@cassandradover if you can. Use this guide ASUS Q405U 배터리 교체 to get to it. Now you are already half way there and it might be a good idea to do the ammeter checking, to see if our battery still draws a charge. If not, I'd replace the battery anyhow,
의
댓글 달기
답변을 추가하세요
Cassandra Dover 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 35
전체 시간: 428
