주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
XIAOMI Mi L32M6-EI TV는 Mi TV 4A 호라이즌 에디션(32인치)이라고도 불리며, 2020년에 출시된 HD 레디(1366 x 768) 스마트 안드로이드 LED TV입니다. 이 기기는 크롬캐스트와 구글 어시스턴트가 내장된 안드로이드 TV 운영 체제에서 실행됩니다.
Why my tv gets hang?
I have Mi 32 smart tv, but it's has some issue. Whenever I starts my tv it won't get started but after hours or a day the tv starts but after getting on for above 20 min the tv gets hang, means I can't change the channel or even raise or low the volume, then I have to directly switch off the tv from the plug.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@harshkaran92697 unplug your TV. remove the back cover. Take a look (do not touch) all of the boards and check for any obviously damaged components. Next, take some well focused pictures of all of your boards and post those with your Question. that way we can see what you see. 기존 질문에 이미지 추가하기
You also need to verify that your TV is a 4A L32M6-E If it is not, let us know what model it is.
의
댓글 달기
답변 1개
From what you describe it might be a mainboard issue, more specifically something related to the logic of the TV like the CPU. Given that it takes around 20 minutes to hang, it could be related to thermal stress on the CPU, could be cold or cracked joint on one of the solder balls underneath the CPU, in that case a fix would either necessitate a reflow, reball of the CPU or replacement of the mainboard itself. Of course I cannot assure that without further information, but it would be a good place to start.
From my experience, if a tv shows the standby light and refuses to power on it indicates this type of issue. You might have gotten it to start once or twice by pure luck when the solder joints where making slight contact.
Check out this video of someone attempting a reflow using a hot air gun, keep in mind these are not the proper tools, but If you have nothing to loose and want to give this a shot before buying a new mainboard go ahead! Be careful when working with TV's as they could contain dangerous voltages even after unplugging, only do so if you're comfortable and leave it unplugged for a while.
Best of luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Harsh Karangutkar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 12
전체 시간: 610
