주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DJI Mini 2는 2020년 DJI에서 제작한 소형 드론입니다. DJI Mini 2는 4K/30fps 동영상 촬영과 10km 거리의 720p/30fps 영상 전송 기능을 갖추고 있습니다.
incompatible gimbal data error
powers on connects to drone, camera rotates left,right, up and down can view through camera. gimbal does not respond to wheel on controler. has incompatible gimbal data on display. will not take off. is i a board problem or a cable
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
did you solve this problem?
의 공유
댓글 달기
답변 3개
선택된 해법
Let's do a little logical thinking here.
If the gimbal does its power on movement then the gimbal and cable to it from its controller in the AC are functional.
If you can view the camera, then the camera system and communication from the AC is functional.
The AC sees the gimbal and is getting data but does not like what it sees, so you are getting an "incompatible gimbal data" message.
Therefore, any commands to it from your Controller are ignored (or maybe the Controller isn't even sending the commands because of the error).
If that message appeared after your "minor" crash, then I would first suspect a dislodged cable in the AC.
But after that, a damaged PCB is a possibility.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
I'm afraid the reader does not know about an AC being Altitude Controller, nor where to locate this in the drone...
의 공유
AC is a common abbreviation for AirCraft
의 공유
gps board ended up being culprit,bought new still didnt work, took board from another broken drone and all well now.
의 공유
댓글 달기
You will need to replace the gimbal. The best website to buy parts from is: djioemparts.com.
You can buy a new gimbal here for $80 USD https://djioemparts.com/collections/dji-...
Best of luck, BetaTech Labs Repair AU
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
the gimbal responds to startup/power on and does up down left right chk ok and i can view through camera, does not respond to up/down knob on controler so would that be gimbal or motherboard
의 공유
did it beep at startup?
의 공유
댓글 달기
Hi, Have you done any repairs recently? have you crashed recently?
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
very minor fall from about 8' into grass
의 공유
Yeah, it looks like you messed up your gimbal
의 공유
posting new answer...
의 공유
finally was able to find solution, i replaced gps board and all is once again fine!
의 공유
댓글 달기
답변을 추가하세요
colderp 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 26
지난 30일: 118
전체 시간: 2,936
