주요 콘텐츠로 건너뛰기
삼성 갤럭시 A33 5G는 삼성이 2022년 4월 20일에 출시한 중간 단계 휴대폰입니다.
20 질문 전체 보기
وقع هاتفي في الماء
وقع هاتفي في الماء خارج المنزل وبعد ساعة وضعت الهاتف في الشحن واكتشفت أنه لايعمل فوضعته في الأرز لكن لم يعمل
Google translate:
My phone fell into the water My phone fell into the water outside the house, and after an hour I put the phone on charge and discovered that it was not working, so I put it in rice, but it did not work
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi @faresalhaf21263
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away.
Using rice to fix electronics is a myth. It doesn't work. Rice does not fix the problems caused by corrosion. Rice is for dinner, not repair
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a teardown video that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
خذه إلى فني الإصلاح بسرعة حتى لا يتسبب الماء في المزيد من الضرر
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Fares Alhaffar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 32
