주요 콘텐츠로 건너뛰기
How to update BIOS of C50-B?
I cannot update BIOS from 1.30 to5.10. Please help me.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I had disabled secure boot and enabled cam boot.Still it shows error,ec id check failed
댓글 달기
답변 2개
가장 유용한 답변
What have you tried so far?
Did you read this?
Toshiba Satellite C50 BIOS update
Secure boot and CSM boot setting is important.
The boot menu key is either F12 or F2.
이 답변이 도움이 되었나요?
점수 2
댓글 21개:
I disabled secure boot and enabled csm boot,still no response,It shows ec id check failed
Hi @joeljoseph70261
1.) Did you reset the BIOS by removing/disconnecting the CMOS battery? It could be corrupted.
2.) https://support.dynabook.com/
and type in your serial number just to double check you have the correct BIOS version for your exact laptop model.
3.) Did you format the USB flash drive with FAT 32?
Yes I did,My model does not have CMOS battery
@joeljoseph70261
There is a CMOS battery on the motherboard.
It is a rechargeable battery that is soldered onto the board.
Look for JRTC component on the board
You can also clear the cmos (BIOS) by short circuit on jumper pads JP1 & 2 near the ram door, for about 10 seconds
Does csm os can help update bios
댓글 16개 더보기
댓글 달기
Well I will suggest you to check out the following video: https://www.youtube.com/watch?v=oKpBB31R...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joel Joseph 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 46
전체 시간: 406
