주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1985년에 Sony에서 출시한 AM/FM 라디오 시계인 Sony Dream Machine ICF-C211에 대한 수리 및 문제해결 정보입니다.
Radio will not turn off
I cannot turn off the radio. When I move the slider to the far left, to the off position, the radio remains on. Seems like the switch is broken. Is there an easy fix?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Had the same problem, i opened it up and sprayed contact cleaner in the switch.
After that i took the excess off with some q tips and now its fixed.
Bought mine at a second hand store for 1,50€.
의
댓글 달기
답변 1개
선택된 해법
You didn't meantion how old it is... from the details of the age of being introduced in 1985, I suspect it is well loved.
If you have the skills to open it up while it is off, and in soldering... I would suspect the switch is a through-hole switch. From the part number, you might be able to find a replacement (I use digikey website) and then solder the replacement into place.
If you do, take notes and pictures, and make a service manual to help anyone else who has it too.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks Wolphin. I picked it up at Goodwill for $5. I appreciate your suggestion, but think I'll pass on the repair - old unsteady hands & mind - and use it soley as a clock.
의
댓글 달기
답변을 추가하세요
Buzz Chernoff 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 46
전체 시간: 883
