주요 콘텐츠로 건너뛰기
The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
How can I repair my drifting left stick
I never had a problem in my life with drifting stick but the time has come. So any advice how can I fix this problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
The answer is to either go around is with a q-tip and some isoprypl alchohol rub the q tip around the joystick hole
If that doesn't work try to take an air blower to it to try to take out any dirt and debris
If all else fails you can replace it with this part however be aware that it does require soldering
Replace one controller joystick compatible with an Xbox Series S or Series X controller. Fix issues like drifting or an unresponsive joystick. 이미지
제품
Xbox Series X/S Controller Joystick
$14.99
이 답변이 도움이 되었나요?
점수 2
댓글 달기
You could either try cleaning the potentiometers in the stick with something like BW100 or isopropyl alcohol or just replace the stick. It kinda depends on the severity of the drift if cleaning it would work or if it needs a replacement, so see what works and I hope one of these ways fixes it.
Have a great day!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Michał Długosz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 34
전체 시간: 180
