์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
์ˆ˜๋ฆฌ ์ปค๋ฎค๋‹ˆํ‹ฐ ๊ฐ€์ž… - ๊ณ„์ • ๋งŒ๋“ค๊ธฐ
MSI GL65 9SD๋Š” 2019๋…„์— MSI์—์„œ ์ถœ์‹œํ•œ ๋ณด๊ธ‰ํ˜• ๊ฒŒ์ด๋ฐ ๋…ธํŠธ๋ถ์ž…๋‹ˆ๋‹ค. ์ด๊ณณ์—์„œ ์ˆ˜๋ฆฌ ์•ˆ๋‚ด์„œ ๋ฐ ์ถ”๊ฐ€ ์ •๋ณด๋ฅผ ํ™•์ธํ•  ์ˆ˜ ์žˆ์Šต๋‹ˆ๋‹ค.
Why is my screen off
Please a metal screw fell inside the laptop, stacked between the metal that covers the cpu and the motherboard. I didnโ€™t know so I connected my laptop charger to the laptop and the charger light went off. I tried this several times until I opened the laptop and removed the screw. Now the laptop turns on but the screen is off. When I connect to a monitor, it doesnโ€™t show too. Please what could be the fault
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
You seem to have loosened the heat sink (that metal part) if the screw got trapped onto the motherboard than it is possible that you damaged the motherboard (really bad). You could also try to check the connection to the GPU and the actual card itself for damage and the fragile ribbon cables around it
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
Michael Ashorm ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 1
์ง€๋‚œ 7์ผ: 4
์ง€๋‚œ 30์ผ: 13
์ „์ฒด ์‹œ๊ฐ„: 262
