주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 7a는 Pixel 7 시리즈의 저가형 제품입니다. 2023년 5월에 출시된 Pixel 7a는 페이스 해제, 8GB RAM, 대폭 업그레이드된 카메라, 무선 충전 기능을 갖추어 Pixel 6a보다 개선된 제품입니다.
Screen adhesive re-use
Just completed a glass/screen repair on a Pixel 7a, but got a smudge on the front camera lens during the process. Sadly, didn't notice until after reassembly was complete. Can I re-open the front, clean the lens, and re-close without replacing the perimeter adhesive, or do I need to clean up and use new glue?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Thanks folks, for the minimal cost of new screen adhesive, it's worth the reassurance that it'll be properly sealed.
의 공유
댓글 달기
답변 2개
선택된 해법
I'd say it depends on how well the glass comes off. I had an iPhone X that I had just finished working on but banged my head on the table when I realized I'd forgotten to reprogram the True Tone data. So I opened it back up and found that the precut adhesive had stuck on the phone so it was still completely intact and undamaged. That being the case, I decided to reuse it and haven't seen any problem as a result.
So my take on this as it applies to you is, if the display comes off cleanly and doesn't tear or stretch the precut adhesive, you can probably get away with reusing it. If it sticks partly to the screen or tears / stretches when you get the screen off, then it's time to replace it.
One thing you might do when you put the phone back together is to reheat the adhesive once the screen is on, then place it face down with some weight on it. That'll soften the adhesive and the weight will help seal it. Hopefully that'll help compensate for not using a new sheet of adhesive. I usually go over the phone for about 3 minutes with a hair dryer, then I have a motorcycle battery I set on it for a half hour or so.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
You could, But I would highly recommend not to
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Not nay-saying your answer, I'm genuinely curious: voice of experience, or theoretical problem potential?
의 공유
There’s a potential problem
의 공유
댓글 달기
답변을 추가하세요
Frudougy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 40
전체 시간: 1,326
