주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
V2 컨트롤러는 세대별로 차이가 있습니다. 지금 보시는 제품은 4세대입니다.
Button inputs mixing and matching
I was playing an online game and got so angry that I threw my favourite controller, 5 years old, on the floor full force. I regret it terribly.
I've opened her up many times to change worn out rubber padding. I opened her up again, saw nothing wrong except a broken metal weight on the lower left. Put her together. I use her on PC, so i checked the inputs and they were fine on windows. I check them in game and button inputs are mixing, I press SQUARE and the results with be SQUARE TRIANGE. Or I press R1 and Ill get R1, CIRCLE and CROSS output results. I suspect the green motherboard inside is faulty or needs a replacement? What do think?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
A broken metal part might have caused colateral damage to the PCB that would require careful inspection with a glass to find.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Athi Musoke 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 205
