My horn is not working
My horn is not working. It is not the fuse nor the horn relay how do I fix it
좋은 질문입니까?
좋은 질문입니까?
Hi @ginnytaylor
Is the horn relay operating when you press the horn button i.e. can you hear it click - you may need two people to do this?
Remove the horn fuse and then remove the horn relay and short out pins 2 & 3 in the horn relay socket. Replace the fuse and check if the horns work. You don't have to press the horn button as they should work once the fuse is reinstalled
If they work OK that proves the wiring from the relay to the horns is OK.
If they don't work there's a wiring problem between the relay socket and the horns. Check that the wires are connected securely on both of the horns.
You will need a test lamp or a voltmeter to prove that the horn switch and the combination spiral switch (in the steering wheel) wiring circuit to the relay is OK.
Here's the wiring diagram for the horn circuit for 2011-2016 Juke models, that may help. (you didn't specify the year)
(click on image)
이 답변이 도움이 되었나요?
지난 24시간: 3
지난 7일: 10
지난 30일: 29
전체 시간: 207
